Old 16-Jan-2014, 7:41 PM   #11
Ric2L
Originally Posted by StephanieS View Post
Hi Rick,
Thanks for the added info. I'm concerned about your signal drops with your strong signals in the air, they should be reliable. Do you have trees or other obstructions in the antennas path? How long is your run of coax? How are you splitting?
Yes there are very tall walnut trees on property border to the north south and east. The coax run starting at antenna I have a 30' run to a three way splitter, same splitter that was used for Verizon Fios cable, the first split goes to my bedroom, 15' run; second goes to living room, 50' run; third goes to back bedroom, 70' run; the back bedroom is not is use at this time.
Ric2L is offline   Reply With Quote
