Old 16-Jan-2014, 6:49 PM   #11
Unfortunately, Channel Master has not published polar gain plots for their antennas. But you don't really need the plot, you simply need to adjust the aim of the antenna, then re-scan to see if you add any channels and make note of the changes in signal strength/reliability. If you take you time, and make notes, paper or mental, you'll effectively discover how the antenna really performs in your application which is the only application that really matters (right?).
