Use the interactive map tool as I said, enter the estimated height of the antenna, run a new plot, then post the link to that plot unless it's identical to the old one.
If we don't have an analysis based on a precise location, then any interpretations will be based off faulty data and the old expression of "garbage in, garbage out" applies. It's up to you to prevent that by not having a "garbage" plot.
