Help with mast suggestion
I purchased a Antennas Direct DB4E Antenna, a AntennaCraft 10-Element Channels 7-13 Yagi Antenna and a RCA TVPRAMP1R Outdoor Antenna Preamplifier based on the kind help of GroundUrMast.
If someone has a suggestion on a good 30' telescoping mast and associated hardware to be attached to a stucco wall with a roof overhang of about 10"-12." It would be much appreciated. We would like to put a piece of pipe in the concrete footing in order to be able to remove the mast should we move. What size of PVC pipe should we imbed in the concrete?
Many thanks for this wonderfully helpful forum.......roadrunnerray
