Old 16-Jan-2014, 5:43 AM   #5
Above the roof of the 3 story house will be Ok.
The Tv stations are to the West and East.
The West Tv Stations are Weak signal strengths.
The East Tv station that is your strongest Tv signal is , KTIN , PBS.
For reception in a West Facing Window on the 3rd floor , you can Test reception with a , http://www.channelmasterstore.com CM4228HD , antenna with a , Channel Master 7778 , preamplifier , from Channel Master or from http://www.amazon.com
I recommend the 3 story roof because the first story roof may have the house blocking reception to the East.
Above The Peak of the Roof install the CM4228HD antenna aimed at about 262 degree magnetic compass direction.
Buy the HFS-2D and HFS-3D splitters at , http://www.hollandelectronics.com.
A http://www.ronard.com/909911.html ,
ronard(911) , 3 foot tripod antenna mount will make good antenna stand in the West window.
And the 3 foot tripod can be used up on the roof.
Here are some more above the roof antenna mounts.
Buy the ronard antenna mounts at , http://www.ronard.com.
