Old 16-Jan-2014, 5:31 AM   #3
I see StephanieS posted a good response as I was typing... Her two antenna solution is a very good option. As she already observed, KGO and KNTV force you to consider using a combination UHF/H-VHF antenna or two separate antennas.
The Winegard HD-7694P would be my first pick. For an alternate, the Antennacraft HBU-44 would be a viable option.
Try running with no amplifier: http://forum.tvfool.com/showthread.php?t=13646
The bottom line is, you can do this successfully, and you have options.
