Old 15-Jan-2014, 9:18 PM   #1
Kevin
Help with TV antenna
Hi,
I am in Southern Ontario and my signal analysis is here:
http://www.tvfool.com/?option=com_wr...5b946d51810248
I have an old TV antenna in my attic that worked well for about a decade. The internal rotator as well as the remote quit working on it. I would like to replace my antenna with one (or two) digital antennas that don't need to be rotated. As you can see in the signal analysis, most of the signals I can receive are from either (approximately) the southeast or southwest. Also, most (if not all) TV signals in this area are now digital. Would it be possible to connect two antennas to a single coax cable using a splitter and avoid using an A/B switch? I have read on here that omnidirection antennas are not that great but if anyone thinks one could work in my situation, please let me know.
Any advice would be greatly appreciated.
Best regards,
Kevin
Kevin is offline   Reply With Quote
