Old 15-Jan-2014, 4:16 PM   #2
Signal strengths are strong and LOS=Line Of Sight.
No antenna rotator required to receive Digital Broadcast Tv Stations/Channels from both directions
Install a , http://www.antennacraft.net , HBU11 aimed at about 170 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
Use No preamplifier.
Use a , 4 way distribution amplifier.
http://www.channelmasterstore.com , CM3414 , distribution amplifier.
Each output of the distribution amplifier goes to a Tv location.
Install All New RG-6 coax outside. Use the coax that has the Compression type connectors on the ends of the coax.
Install a New coax ground coupler/block.
After all is set up and working correctly.
To make double sure that weather and water does not get into outside connections.
Wrap with , http://www.coaxseal.com.
Can also wrap the matching transformer (balun) that connects the coax to the HBU11 antenna with coax seal.
http://www.antennacraft.net.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own building.
Absorbing and Blocking Reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own building.
40 feet up on a tower , should place the antenna away from obstructions in the directions of reception , North and South.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels.
Scan for , ATSC-Digital Broadcast Tv Channels.
