Old 15-Jan-2014, 2:14 PM   #9
tomfoolery
When I was searching the attic for a good antenna location, I used an old converter box and small CRT TV that I brought up with me, which saved a lot of time climbing the attic stairs and walking back and forth to the far opposite end of the house.
Once I found a location that gave a clean signal on all channels, I mounted it to the trusses, then used the signal meter on the big TV (on the other end of 100 ft of RG-6) to fine tune a little. But having a signal meter close by saved a ton of time and aggravation.
Just a suggestion.
tomfoolery is offline   Reply With Quote
