Old 15-Jan-2014, 12:22 PM   #8
I'm not snarky, I'm "matter of fact". I don't sugar coat instructions and advice, especially when it's being avoided.
If the signals are being received from a direction other than expected, tht usually means that the direct signal path is blocked and that the off-axis signals are getting to the antenna via an indirect method of propagation, either by reflections or by diffraction. Usually such propagation paths lead to multi-path and less reliable reception.
Keep searching for a "sweet" spot. Use the tips I provided earlier to scout out locations that are good prospects, then test those locations to see if they work out.
