Old 15-Jan-2014, 5:18 AM   #2
The Topeka area Digital Broadcast Tv Stations/channels are strong signal strengths.
And will most likely be received.
Aim the antenna at about 96 degree magnetic compass direction , Kansas City.
Directional antennas such as and not limited to the Winegard HD8200U antenna , receive the best at the front of the antenna , a little less at front angles to the antenna , less at back angles and back of the antenna.
Directional antennas receive the least amount of signal directly on the sides of the directional antenna.
Looking at the radar plot.
See that aiming the antenna at about 96 degrees magnetic compass direction , puts the Topeka Tv stations at a back angle to the antenna , so the strong signal strength Topeka Tv stations should be received.
Aim the antenna and scan for channels.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
http://www.tvfool.com/?option=com_wr...5b949386a58905.
