Old 15-Jan-2014, 3:45 AM   #4
bobdole888
Originally Posted by No static at all View Post
Please describe your poor reception. Is reception worse overall, or are you missing certain channels? Is the Roamio set for OTA or cable? If set for cable channels, you will not see any UHF stations.
Why don't you go into tivo settings and read the cable signal strength using both the Romio andn the TivoHD at the same location that you have problem with. See how many dB you are getting for signal to noise ratio.
Your Romio should come with 1 yr warranty. So if the problem is the box, Tivo should be able to replace it for you.
bobdole888 is offline   Reply With Quote
