Hoping and knowing are two quite different things...
Did you verify that there were no satellite splitters or multi-switches remaining in the satellite coaxial lines?
Keep in mind that the satellite signals come from a point up in outer space while the local stations come from some point on the horizon.
Pick a location that offers that "best" signal path view and go there first with the antenna. Make sure the front (bowties) of the antenna is facing towards those stations' towers.
