Well I know I am digging up an old post but I wanted to ask a question with the reception of the close stations in my set up.
I have installed the CM2016 antenna pointed at about 344 magnetic degrees and I receive a ton of stations! Even during bad weather days I receive a ton of Canadian stations without issue!
However I do not receive WNLO and WNED is choppy sometimes.
I currently have the coax line from the antenna into a 2 way splitter that has one line run to a television, and the other run to a TIVO Roamio.
I can live without WNLO, but WNED is the local PBS station, and I do like some programming. Is there any way to reduce the signals coming from these two stations so it doesn't overload my TIVO/TV?
Btw, WUTV comes in without any issues.
Thanks.
