Old 14-Jan-2014, 7:16 AM   #4
The Local Digital Broadcast Tv stations/channels can be received with a , http://www.antennacraft.net , HBU11K antenna installed Above The Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South East , South , South West , West , North West , East North North East.
Aim the HBU11K antenna at about 208 degree magnetic compass direction.
These Local Digital Broadcast Tv Stations/Channels.
KFXK-DT REAL UHF Channel 31 FOX , and digital sub channel KTPN/KLPN MyNetwork.
KECB REAL UHF Channel 51 Me-Tv and Mundo Fox.
KLTV-DT REAL VHF high band Channel 7 ABC and digital sub channels Bounce and Tele-La-Vida.
KLPN the same as KTPN REAL UHF Channel 47 MyNetwork.
KLGV-LP REAL UHF Channel 36 TBN.
KETK-TV REAL UHF Channel 22 , NBC and digital sub channel Estrella Tv.
KYTX-DT REAL UHF Channel 18 CBS and digital sub channels CW Plus and COZI Tv.
A antenna system amplifier will most likely not be required.
To find what Networks are being transmitted by the Tv stations and Much More Interesting and Useful Information , this is the way I find the information.
As an example , type variations of the Tv station Call Sign in the , google or yahoo search box , as an example , kytx , kytx tv , kytx-tv , kytx-dt and etc. .
Two web sites that will be found that have a lot of Practical and Useful information concerning the Tv station/s are.
http://www.wikipedia.organd http://www.rabbitears.info.
http://en.wikipedia.org/wiki/KYTX-TV
Some satellite systems will allow the connection of and distribute the Tv antenna reception to the Tv's and some satellite systems Will Not.
A diplexer arrangement will be used to connect the satellite system and Tv antenna.
A diplexer combines the satellite signal and Tv antenna on to one coax and then a diplexer separates the signals at each Tv location.
Some satellites systems can do this and some can not.
