Old 13-Jan-2014, 10:11 PM   #3
A Simple reception situation.
A 1 Antenna Solution.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West , South , South East , North West.
Install a , http://www.antennacraft.net.
HBU44 antenna aimed at about 180 degree magnetic compass direction.
Install a , http://www.channelmasterstore.com , CM7778 preamplifier.
Fo 3 Tv's connected use a , Holland Electronics , HFS-3D , 3 way splitter.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
The Digital Tv Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channel.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal serach box or buy from , http://www.ronard.com.
http://www.amazon.com.
http://www.solidsignal.com.
