Old 13-Jan-2014, 9:36 PM   #5
CKWS-DT VHF high band channel 11 , CBC , is easy to receive.
For Reliable Reception of Digital Tv Stations/Channels , more Tv stations both USA and Canada that are weak and weaker signal strengths.
WPBS-DT , REAL UHF Digital channel 41 , PBS.
CICO-DT , REAL UHF Digital channel 26 , TVO.
WWIT-DT REAL UHF Digital channel , 21 , ABC.
WWNY-TV REAL VHF high band channel , 7 , CBS.
And these , Analog Tv Stations Channels.
CJOH-TV , Analog channel 6 , CTV.
CIII-TV , Analog channel 2 , GTN.
Install a Winegard HD7084P antenna.
Install a , RCA , TVPRAMP1R , preamplifier.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.amazon.ca.
http://www.amazon.com.
http://www.hollandelectronics.com.
At no less then 40 feet antenna height above ground.
http://www.winegardirect.com.
HD7084P All channel antenna.
Aim the HD7084P antenna at about 128 degree magnetic compass direction.
Use a REAL and Actual magnetic compass to aim antenna.
Yes you can Test reception at lower antenna heights above ground.
Last edited by teleview; 14-Jan-2014 at 11:22 PM. Reason: Clarify information and typos.
