Old 13-Jan-2014, 8:38 PM   #1
Ric2L
Need some help with antenna choice & alingment
Hello
I recently decided to get rid of cable and go with OTA TV. Here is my signal analysis results. http://www.tvfool.com/?option=com_wr...5b9436a40abb65
Right now I have a clear stream 2 antenna I purchased from Best Buy, I can pull in my local channels most of the time, but I loose signal for a couple seconds every 5 or 10 mins. on a couple stations. Most of the channels are to the north east except for FOX which is to the south east. Also, I can only pick up FOX on the TV in my bedroom (which is a newer Samsung 40" LCD). The older Samsung plasma in the living room won't pick up fox at all, unless I turn the antenna, thus loosing other stations.
I would like to replace this antenna with a better one and hopefully receive all channels on both TV's while not turning antenna.
Any suggestions would be greatly appreciated.
Thanks Rick
Oh yea, The antenna is mounted about 30 feet in the air on a telephone pole right beside my mobile home.
Ric2L is offline   Reply With Quote
