Old 13-Jan-2014, 4:05 PM   #2
A Simple Reception situation.
For reception of the Local Digital Broadcast Tv Stations/Channels.
Install a , http://www.antennacraft.net.
HBU11K antenna Above The Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North East , South , South West.
Aim the HBU11K antenna at about , 190 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
A antenna system amplifier will most likely not be required.
For 2 Tv's connected use a 2 way splitter.
http://www.amazon.com.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing , Blocking , Reception.
The Best Practice is to install the HBU11K antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
And Do Not channel scan for only , Analog Tv channels.
Go into the Digital Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
