Old 13-Jan-2014, 3:28 AM   #4
95% of the reception information provided here at tvfool.
Is Basic Antennas and Reception information.
And is not above pay grade.
We here in the USA and Canada are now 2 generations removed from a time when the only way to receive Tv was with a Tv antenna.
And Many People had a Basic knowledge of Broadcast Tv Reception , What antenna or antennas to use for the area of reception and where the Tv transmitters are located.
_________________________________
For reception of your channels list.
KSPR , ABC and The CW.
KOLR , CBS.
KYTV , NBC.
KWBM , Daystar and Digital sub channel , FOX.
Install a , http://www.antennacraft.net , HBU44 antenna Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception , in the directions of , North West , West , South East , North East.
Aim the HBU44 antenna at about 330 degree magnetic compass direction.
As always the starting antenna aim direction is the --->starting antenna aim direction.
The antenna aim direction and the location of the antenna can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some digital Tv's also have a , Signal Quality Meter.
Install a , RCA , TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
http://www.antennacraft.net.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.ronard.com.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
In addition to your channels you have requested , also be looking for.
KOZL , Independent Tv Station.
KOZK , PBS. Ozark Public Broadcasting.
K26GS-D , http://en.wikipedia.org/wiki/K26GS-D.
COZi Tv , Antenna Tv , This Tv , Me-Tv .
KEMV , PBS , Arkansas Educational Tv Network.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception in the dorections of reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 13-Jan-2014 at 8:45 AM. Reason: Clarify information and typos.
