Old 12-Jan-2014, 10:35 PM   #3
The Current Broadcast Tv Channels that are transmitted and received in the , USA , Canada , Mexico , are.
UHF channels 14 thru 51.
The VU 190 , Is a Big All Channel Antenna that receives all the channels.
Aim the VU 190 , at about 146 degree magnetic compass direction.
Here is how to aim Tv antenna , www.kyes.com/antenna/pointing/pointing.html
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
The reception signal strengths are strong signal strengths.
A antenna system signal amplifier is not required for reception at your location.
Remove and Discard All parts of the radio shack amplifier.
Remove and Discard the Preamp Unit.
Remove and Discard the Power Injector.
Remove and Discard the Power Supply.
To -->Prove Reception<---.
Remove and Discard the , Matching Transformer , (Balun) .
That connects the VU 190 antenna to coax.
Connect a New Matching Transformer to the VU 190 , antenna terminals.
Connect a NEW Continues Length of Coax to the New Matching Transformer.
Run the New Continues Length of coax through a open door or window , direct to 1 Tv.
Connect the New Continues Length of coax direct to the 1 Tv that has a , ATSC- Digital Broadcast Tv Tuner.
The NEW Continues Length of coax , Bypasses every electronic and electric device and connects to a Digital Tv that has a , ATSC-Digital Broadcast Tv Tuner.
Scan for Channels.
The Digital Tv Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Stup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels~.
Scan for the ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 13-Jan-2014 at 6:33 AM. Reason: Clarify information and typos.
