is there another antenna (same size as the 751) I can buy that is specialized to the VHF Low?
No. The physics say that the antenna element lengths are proportional to the wavelength of the frequencies desired. That means, for a VHF-low antenna to have the same performance as a high-VHF antenna, its elements should be around twice as long.
I often suggest our 3-element FM antenna for channel 6 operation. It actually works really well but it certainly isn't small by any means.
Getting your antenna up in the air may well help as it might simply be picking up electrical noise where it's currently at.
