Adding to elmo's comments, try the ANT-751 outdoors, where it has access to more signal and less electronic noise from inside your house. If it fails to give you reliable reception of the signals you want, then step up to an all channel antenna such as the Winegard HD7084P (premium option) of similar product such as the Antennacraft HD1200, HD1800 or HD1850.
Reason: sp.
