Television signals are transmitted in either horizontal or elliptical polarization. This means that the DB4e and similar antennas will perform best if oriented so that the 'bow-tie' elements extend left and right of the antenna center line. You will loose a significant amount of performance if you rotate the antenna 90° from it's designed orientation.
Generally, mount the UHF antenna at the top of the mast, and the VHF antenna 3' to 4' below. This means that a 5' mast lacks the room needed for a UHF and separate VHF antenna.
UHF and VHF antennas produced commercially (as opposed to home made designs) function well when mounted on a metal mast. The typical metal mast used for OTA TV antenna mounting is about 1 3/8" in diameter. In recent years I have found it difficult to find "TV antenna mast" in lengths other than 5'. My solution has been to use chain-link fence top-rail. I find it in stock at places such as Home Depot. It's 1 3/8" in diameter and 10.5' in length. It even has a swedged end, designed for stacking multiple sections end to end. And perhaps best of all, it's reasonably priced.
Reason: chain-link top-rail
