Old 11-Jan-2014, 7:50 PM   #11
Originally Posted by No static at all View Post
Unfortunately, that's not the problem. The channels you are seeing are on UHF, so the setting is correct.
The solution is a better antenna, placed where it is able to receive a higher quality signal.
Agreed.
Keep it simple, start with only the antenna, a known good length of RG-6 coax not longer than 50', and a TV. Splitters and amplifiers will only complicate the situation until the basic antenna can deliver a reliable signal. http://forum.tvfool.com/showthread.php?t=13646
