Old 11-Jan-2014, 3:59 AM   #8
The Tv Must Channel Scan for , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for the , ATSC-Digital TV Channels.
DO NOT channel scan for , Analog / Analog HRC , Only , Channels.
Analog Channels / Analog HRC , Are Not , ATSC-Digital Channels.
So DO NOT channel scan for just Analog and Analog HRC channels.
For reception of the , Tvfool Digital Current Plus Pending Applications Included Tv Stations/Channels and Channel List in the , Green and Yellow reception zones of the tvfool radar report and channel list.
Above the Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , the , OTA=Over The Air , ATSC-Digital Broadcast TV Transmitters that provide the , ATSC-Digital Broadcast TV Reception at your reception location.
The directions of reception at your location are , North East , East , South East , South , South West , West.
As you can see looking at the tvfool radar plot , the Main Group of , ATSC-Digital Broadcast TV Stations are to the , East.
Install a http://www.antennacraft.net , HBU11 antenna aimed at about 90 Degree Magnetic Compass Direction --> EAST.
Install a , Winegard , LNA-100 'Boost" , antenna system amplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.antennacraft.net.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
Absorbing , Blocking , Reception , In The Directions of Reception.
Multi-Path Reflecting Tv Signal Bouncing All Around.
The Best Practice is to install antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 12-Jan-2014 at 4:41 PM. Reason: Clarify information and typos.
