Old 11-Jan-2014, 2:39 AM   #7
The Canada , Digital Broadcast TV Stations Channels are Strong Signal Strength and Easy to Receive.
The insides of buildings and attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
For indoor type Tv antenna.
Reception is better when the indoor type antenna or even a outdoor antenna is placed in/at a , window or patio-balcony window or patio-balcony door window.
The reason reception is better in/at a , window , is , window glass more easly passes Tv signals through the glass , then , wood and sheet rock walls , metal and metal walls , one example and not the only example of metal walls is/are buildings that's warped with -stucko wire.
Also metal siding and metal roofs are not good for reception and more examples of building materials that are not good for reception.
Any way place a , Terk HDTVi antenna in/at a , window , patio-balcony window , patio-balcony door window that faces , North North East.
Aim the Terk HDTVi (not HDTVa) antenna at about 30 degree magnetic compass direction.
Here is how to aim indoor and outdoor Tv antennas.
www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antennas.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna aim direction and location of the antenna be adjusted for best reception.
Most Digital Tv's have , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Last edited by teleview; 12-Jan-2014 at 6:18 AM. Reason: Clarify information and typos.
