Old 10-Jan-2014, 4:11 AM   #3
A Simple reception situation.
The signal strengths of Digital Broadcast Tv Stations are strong to moderate signal strengths.
Above the Peak Of The Roof in such a manner that reception is not , obstructed , impeded , blocked by the roof and building , install a , http://www.antennacraft.net , U8000 UHF channels 14 thru 51 antenna aimed at about 129 degree magnetic compass direction.
Install a , http://www.antennacraft.net , Y5-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 280 degree magnetic compass direction.
Connect the , U8000 antenna and Y5-7-13 antenna together with a , EU385CF-1s , UHF/VHF combiner.
Connect the U8000 antenna to the UHF connection of the combiner.
Connect the Y5-7-13 antenna to the VHF connection of the combiner.
The remaining connection of the combiner goes to the Tv/s.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.antennacraft.net.
http://www.ronard.com.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking , Reception.
The Best Practice is to install the antennas at location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
