Thread: Perplexed
Old 22-Nov-2010, 1:31 PM   #5
MyHD120
Originally Posted by No static at all View Post
I don't think the antenna being installed upside down is the issue. Are using a preamp? You may see some improvement from a Winegard HDP-269 or 8700 preamp.
My gut feeling is that the 3671 is not strong enough on UHF for your situation. The VHF should be doing better, but you may need an FM trap to help out with those stations.
The stations from NYC are not broadcasting with very high power which isn't helping either.
No preamp at the moment. Wanted to get the raw signal first. I thought a pre might cause noise and degrade what signal there is.
MyHD120 is offline   Reply With Quote
