Old 8-Jan-2014, 8:03 PM   #1
teaguecl
UHF and VHF from different directions, plus airplanes
I'm having some trouble determining the best antenna for my situation, any advice would be appreciated.
My TV Fool report is here: http://www.tvfool.com/?option=com_wr...5b946f88bbc5ce
I am really only interested in the first 7 channels on the report. It turns out am in directly in between the two towers of interest - they are 172 degrees apart from each other (one is at 121 degrees, the other at 293). I'm not that far from either tower, 13 miles and 7 miles respectively. It turns on that one tower broadcasts all UHF (channels 18,19,28,30,40) and the other one broacasts two VHF (8,10).
So it seems like I need a VHF antenna pointed at 293 degrees, and a UHF pointed at 121. My first attempt was to use a Winegard gs-1100. From looking at it's gain chart it seemed to be pretty good about picking up two signals that are 180 degrees apart (http://www.winegarddirect.com/pdf/spec_SENSAR.pdf).
It actually works OK. I see all the channels I am interested in, with a few notes.
1. The two VHF channels come in fairly weak most of the time.
2. I live near a small airport and whenever a small plane (cesna) or helicopter are within earshot, the signal drops out for 10-20 seconds.
I have tried placing the gs-1100 in two positions. First I had it about 12 feet off the ground in my attic, which worked decently but not great. Next, I moved it to sit on my garbage cans (so about 3 ft off the ground) outside. This position works much better, but I still get dropouts due to the planes.
What should I do? I've debated the following actions, but really don't know.
1. Try mounting my gs-1100 on the roof. I don't know if elevation will help at all with the multipath problem from the planes.
2. get a new omni directional antenna (RCA ANT800F ?) I think the omni might give me more problems with the planes than the directional.
3. get a different directional antenna that has a good pickup from the back side, but I don't know what model that would be.
4. Place separate VHF and UHF antennas on a mast, pointing in opposite directions. The only vhf antennas I've seen are huge (10 ft long), which seems unnecessary since the VHF signal is only 7 miles away.
I'd love to get some opinions as I'm not very knowledgeable about this stuff.
teaguecl is offline   Reply With Quote
