Old 8-Jan-2014, 4:01 AM   #3
The >< shaped metal wires are the receiving wires.
This is the front of the antenna.
______________________________________________
The metal rods behind the wires , are the reflectors , that reflect more signal to the >< shaped metal receiving wires , then the >< shaped metal receiving wires , can receive without a reflector.
The metal reflector rods will reduce and block signal that arrives at the back of the antenna.
___________________
To prove that the metal reflector rods will reflect Tv signals away from the >< shaped metal wires.
Aim the Back of the antenna at a Weak Signal Strength Tv Station/Channel.
Now aim the Front of the antenna at the Weak Signal Strength Tv Station/Channel.
If you will like to prove that the metal reflector rods are providing more signal to the >< shaped metal reception wires at the Front of the antenna.
Then remove the metal reflector rods , so that only the >< shaped metal reception wires are receiving the Weak Signal Strength Tv Station/Channel.
