The UHF Channels are 14 thru 51.
The directional aspects of UHF frequencies can produce reception situations that seem odd and unusual.
Reflections off of buildings and trees can produce directional effects around the compass directions.
And the UHF frequinecs can be directional , having more or less signal strength at , higher and lower , elevations above ground.
Reception can be improved by raising and lowering and or moving the antenna from the current location.
Try raising and lowering the antenna , sometimes a few inch's will improve reception and sometimes greater adjustment is required.
_____________
---->Also , Avoiding Obstructions in the Direction/s of reception is Important.<----
_____________
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Signal Quality is Important for Reliable Reception.
Reason: Clarify information and typos.
