Old 7-Jan-2014, 5:49 PM   #2
The provide Tvfool report says, the location is resolved to block level only.
The area that you live is a tough reception area.
Some locations are worse and some reception locations are better.
So as to have best and most accurate reception/location information.
So the best most effective antenna and amplifier and etc. can be recommended.
Please make and post a Tvfool report with the exact address.
Go to the Tvfool home page and click on , >>Start MAPS<<.
Enter the Exact address , make the antenna height 25 feet above ground in the Tvfool report.
If the exact address does not work , then use your zip code only and move the pointer to your exact location.
Make and post the Tvfool report.
