Old 7-Jan-2014, 2:10 PM   #16
Concerning the electric code of wiring and grounding.
The usage of non common word/concepts.
As an example.
The word , bond / bonded / bonding.
Simply means to make a electrical connection that will continue to make electrical connection.
There is also an important part of the definition that calls for the conductor to be up to the task. The NEC definition is rather straightforward,
Bonding (Bonded). The permanent joining of metallic parts to form an electrically conductive path that ensures electrical continuity and the capacity to conduct safely any current likely to be imposed.
(NEC, 2005 edition)
Bleeding off a small amount of static charge doesn't take a heavy conductor, but the current during a lighting induced surge or short circuit fault would explain why the codes call for a heavy gauge conductor between ground rods.
