Old 6-Jan-2014, 6:49 PM   #3
mulliganman
What's a "100 mile" antenna? What amplifiers?
You do know that Bolivar is 30 miles NORTH of Springfield, don't you? What is the actual compass heading that the antenna is aimed at?
I am well aware of where Bolivar is. I don't have the name of the antenna or amp and was relaying what my installer simply told me. I am assuming the "100 mile" is simply the range of the antenna. I can attempt to contact him and see if he can give model numbers. As far as compass heading goes, I don't have one and don't believe he used one. He would aim and I checked signal strength as we tried different aims. The current aim direction is where we got the strongest signal using this method. He is the only installer I could find for my area so I was kind of stuck with what he came up with. If you have installers in your network for this area, I would be glad to listen if it is determined there are other solutions that could resolve my issue.
mulliganman is offline   Reply With Quote
