The antenna and coaxes that are used for the antenna and antenna system.
Must Not Be Connected to the cable tv system service , Must Not be connected to cable internet service , Must not be connected to cable phone service.
The cable delivered services must be on Separate Coax.
Some satellite systems will accept and distribute Tv antenna reception.
Check with a satellite system installer.
I do not recommend connecting the antenna and coaxes that are used for the
antenna system to any part of the satellite system.
Reason: introduces to many situations of reception problems.
If satellite reception is discontinued , then Disconnect and Remove All satellite system componets such as and not limited to , multi-switches , multi-plexers , splitters , couplers , amplifiers , power injectors , power supplies , and etc. .
Yes the satellite system coaxes can be used for antenna system distribution.
