Old 6-Jan-2014, 3:06 AM   #4
Install a , http://www.antennacraft.net , HBU44 antenna Above The Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of reception , East , South East , West South.
Here are some Above The Roof antenna mounts.
Buy the ronard antenna mounts at , http://www.soldsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
http://www.antennacraft.net.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.hollandelectronics.com
Aim the HBU44 antenna at about , 67 degree magnetic compass direction.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Test reception With and Without a , RCA , TVPRAMP1R , preamplifer.
When Testing reception without the preamplifier , disconnect the , preamp unit , power injector , power supply.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
The Best Practice is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for , ATSC-Digital Broadcast Tv Stations/Channels.
