Old 6-Jan-2014, 1:45 AM   #3
If you will like to have reliable reception of the stronger signal strength Tv stations/channels and also reliable reception of the weak and weaker signal strength Digital Broadcast TV Stations Channels.
Such as and not limited to the weak signal strength , KFTO-CD , REAL UHF Tv channel 36 , http://en.wikipedia.org/wiki/KTFO-CD.
http://en.wikipedia.org/wiki/GetTV.
Above The Peak Of The Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception to the , South , South East , West North , North North East.
Install a , http://antennacraft.net , HBU44 antenna aimed at about 180 degree magnetic compass direction.
Install a RCA , TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
http://www.antennacraft.net.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.ronard.com.
Buy the ronard antennas mounts at , http://www.solidsignal.com , or , http://www.ronard.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path Tv Signals Bouncing All Around.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ DTV Channels ~ Antenna Chjannels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select the ~ DTV Channels ~ Antenna Channels ~ Air Channels ~.
Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 6-Jan-2014 at 7:41 AM. Reason: Clarify information and typos.
