Old 6-Jan-2014, 1:31 AM   #19
mhouston
Stephanie
This is all very interesting. I guess to recap. What I need to first do is to disconnect my pre amp and power supply adjust the antenna to see if I am getting too much signal overload. If that works well then perhaps consider a rotor to dial in the signal. Then consider an additional antenna to pick up the Hi-V signal.
I am able with the antenna I have now able to pick up ABC WCTI (RF 12) Greenville, CBS WNCT (RF 10) Greenville so it might not be necessary for the Hi-V or will the additional antenna pick up these channels even better?
mhouston is offline   Reply With Quote
