Old 6-Jan-2014, 12:37 AM   #14
StephanieS
All three are UHF broadcasts. With a rotor you would not need a second antenna for these stations. Your 4228 is designed for these channels.
A second antenna might recommended for ABC WCTI (RF 12) Greenville, CBS WNCT (RF 10) Greenville and ABC WTVD (RF 11) from Raleigh.
This is because they operate on a different band than UHF and what your 4228 is designed to receive. It will depend if you get lucky and your 4228 receives those high-VHF signals.
Rotors can be found here: http://www.solidsignal.com/cview.asp...nna%20Rotators. I'm not up on the best rotors with remotes, so I'll let other guide you there.
Originally Posted by mhouston View Post
I forgot to ask if I want to receive WRAL, WITN and WWAY for example should I consider another antenna than the one I have?
