Old 6-Jan-2014, 12:07 AM   #8
mhouston
Testing for overloading questions
StephanieS,
Again thanks for the reply.
To check overloading can I simply just disconnect the power amp and go direct to the TV without disconnecting from the preamp on the outside or must both be disconnected?
Also to check for over loading if I want to pick up WRAL 5.1 due to the distance from the transmitting tower would I more than likely need a signal amplified even if I added a rotor to zone into the direction of the signal?
Thanks
mhouston is offline   Reply With Quote
