Old 5-Jan-2014, 10:14 PM   #4
sztv321
Thanks to both of you for your quick response.
GroundUrMast, I'll check out what you are suggesting some time later tonight and most likely follow up with an additional response as I am sure I will have questions.
StephanieS, here is the info you asked for:
50 feet:
http://www.tvfool.com/?option=com_wr...5b94db9d6afdb4
100 feet:
http://www.tvfool.com/?option=com_wr...5b94cc01c02515
I was fairly certain an attic antenna wasn't going to cut it, but I thought I would ask anyway. Not that I am against a 50' or 100' pole, it does kind of freak me out a little though to have that thing towering above my house like that. I know I would have to properly ground it. I would just want to get everything as cost effectively as possible and then ensure I put it up properly/securely so that wind and lightening and other elements are (hopefully) a non issue.
Thanks again!!!
sztv321 is offline   Reply With Quote
