Old 5-Jan-2014, 9:46 PM   #6
mhouston
ADTech,
Thanks for the reply. Based on CM4228HD does that mean I should consider a rotor? Again I did not install this I am only able to see the power supply so I assume that a Winegard pre amp was used. I do not own a ladder to go up to the antenna to see the actual pre amp model I assumed that the installer bought them as a kit.
mhouston is offline   Reply With Quote
