The TV is a Sony KDL-46XBR9 from around 2009-2010. I just did a factory reset to see if it made any difference and it did not.
I do have another Sony TV (different model), I'll see if it performs any better.
Edit: The other TV is working MUCH better even though the antenna (ANT751) is currently just sitting on a box in the garage, not even aimed particularly well.
So either I have some interference that affects my main TV or its tuner is just not so great.
Edit 2: OK, I reconnected my main TV; had the same problems. Removed all of its connections (HDMI and network cables) and the problems seem to have gone away. So I think I just have interference from some other cables/connections. Will try to narrow it down to which one is causing the problem and put the antenna back in the original attic location and see if things are good!
Thanks for all the help - will update with a (hopefully) final resolution.
