Hi Sztv321,
Your tvfool radar plot presents some challenges with weak signals come at you from all directions.
GroundUrMast in suggesting the 91xg/Y10-7-13 working with the TVPRAMPR1 gives you the best chance at reception. I would do as he says and zero in on Atlanta first and see what you get. Orientate both antennas to magnetic 274. Then perform scan on TV.
Mounting in the attic is not an option for you. You are dealing with weak signal strengths. Any chance at Atlanta broadcasts will require you to have the antennas outdoors clear of any obstructions in the direction they are pointed.
Can you rerun your TVfool radar plot at elevations of 50' and 100'? Out of curiosity tested a plot for Walkinsville at the city level and at 50' substantial improvement over your 25' plot showed up. I'd like to see if that holds for your specific location as well.
Cheers.
