Beware of the cheap (though they may cost a lot) antennas that claim 150 mile reception.
Your situation calls for a high performance antenna system. The combination of an Antennas Direct 91XG + Antennacraft Y10713 is at the top of the list of off the shelf options. The RCA TVPRAMP1R is a very good preamp to consider.
I'd start with one set of antennas. Scan the Atlanta direction and the Greenville directions. Then decide if a single fixed aim will be adequate, or do you need to add to the system
