Old 5-Jan-2014, 6:01 PM   #2
Limiting yourself to an attic installation is going to result in less reception of available signals. It's a bit like buying an expensive camera and then trying to take pictures through dirty window glass, and in some cases, with the shades pulled and shutters closed.
If we were neighbors, you'd see a chimney, eve or tripod mounted 10' mast on my roof. I'd opt for a large combo antenna such as the Winegard HD7698P or Antennacraft HBU-54 or HBU-55.
Depending on the results I got, you may see me add a second antenna aimed at a second group of signals.
