Old 5-Jan-2014, 5:37 PM   #3
As points of Reference.
The NM(dB) signal strengths of Tv stations / channels are very weak signal strength.
And have 2 Edge Path obstructions.
XETV-DT REAL UHF Channel 23 , The CW.
XHDTV-DT REAL UHF Channel 49 , MyNetwork.
A Reference antenna height above ground is 25 feet.
25 antenna height above ground provides a good evaluation of what is receivable.
For more information.
Please make and post a tvfool report with the antenna height of 25 feet above ground.
DO NOT Delete the First Tvfool Report of 13.1 feet antenna height above ground.
The Current Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in the , VHF high band and UHF band.
Tvfool channel list colunms show the , REAL Channels that are Transmitted and Received.
And the , virtual numbers.
As to the Federal Antenna Law.
The Federal Antenna Law , was and is , written to provide legal rights to protect you and millions of other people from over bearing Hoa's and etc. .
You are Not Required to seek the permission of the people of the Hoa board to install a Tv antenna at your location.
My evaluation so far is that a Tv antenna above the roof of the house will , Easy Be With In , the guide lines of the Federal Antenna Law.
http://www.fcc.gov/mb/facts/otard.html.
