Old 5-Jan-2014, 5:35 PM   #4
I would expect the Terk FDTV2A to perform about the same as the Mohu Leaf. As ADTech has said, you're at a disadvantage to start with given the indoor setting.
Consider the RCA ANT-751. Even though it's an outdoor design, it's small enough for some indoor applications. However, like any other antenna, it won't work well if blocked by building(s) or vegetation.
