Old 5-Jan-2014, 4:55 PM   #3
Assuming that the TVFool data is correct and all those stations are on the air (I do not know):
1. Forget the small UHF antenna all your stations are high-VHF.
2. A small high-VHF antenna like the ClearStream 5 aimed to the southeast should work fine. Channel 11's signal is plenty strong enough to be received off the rear quarter.
3. You don't need that channel 7 signal, it appears to be a duplicate of CKCK.
4. Be prepared to move the antenna around in the attic, avoiding metal objects as much as possible.
Good luck!
